There is a program out there on the internet called IRedit
A guy wrote the code and was selling it at on point but I think he was forced to stop selling. I paid 20 bucks for it 2 years ago.
This program will convert amx to ******** and IR files for pronto and vis-versa. If you can't find it message me.
Timmaa
I've downloaded but not tried a program called 'Vert'. It supposedly converts between all forms of IR files. The website is www.remoteyou.com. Look under the Files tab.
It it true that you can drop in the Hex code directly, but you can not view the hex codes past that. Thats why I still use IREdit to go backwards to pronto when needed IE nothing gets hidden.
I've got some VB code that reads the AMX ir's and extracts the IR code - and vice-versa - not sure where I got it from, but message me if you want it...
Mentioned above program called IRPro by Tony Marona. Its was free (at least ) at Remotecentral. Converts Pronto-AMX-C$$$$$ in any way.
I used it to get Pronto codes from AMX .ir files.
If you need it I can post it here (Size about 3 MB).
Timmaa
Cam
Sergey.
