Tested 1-way rs232 mode with IR Port
                                  in AMX Hardware
                    I have tested the infamous 1-way rs232 (data) mode with the new NI-board firmware and it seems to work.
use: send_command dvIrPort,'SET MODE DATA' followed with the normal set baud command (data_event--> online).
I tested with sending strings to an Extron switcher, the settings change accordingly.
This is great for utilizing IR ports with simple rs232 equipment.
btw, tested with a NI-2000
Great job and thanks for the report.
Brian
- Chip
