Deffective AXB-IRS4?
                                  in AMX Hardware
                    Hi there,
I have an AXB-IRS4 here which LEDs light fine but fails to control the device through the attached IR emitter.
I have doublechecked everything by swapping the controlled device, the IR emitter, the AXB-IRS and it it is definitely the IRS4 device.
When I actuate an IR code from IRedit, the red LED on the IRS4 flashes fine but the controlled device do not respond. The IRS4 is set to AXlink operation with the internal jumpers. I have checked all 4 ports without luck.
Is it possible that the internal battery needs to be replaced?
Any ideas?
Bob.
Any ideas?
Bob.
Go figure.
