Serial Control of DirecTV H20
TurnipTruck
Greetings,
The newer HD receivers from DirecTV no longer have that wonderful "Low Speed Data" jack on them. I really enjoyed being able to get all kinds of feedback from the jack.
The new H20s have a USB port, but I don't know how it could be used for serial control.
Any ideas?
Thank you.
Any ideas?
Thank you.
Could someone recommend such a device? I didn't know they existed for this type of application. Don't USB connections require existance within a Windows machine?
Thank you.
Bafo BF-810
Aten uc-232a
IOGEAR GUC232A (recomended)
The baud rate is 115200.
I have 2 h20s in a system using the iogear adapter at 115200 and it works just fine.
Thank goodness that?s not true.
Yes that is the protocal that I am using, but i have never used the Show Text Command, so i can't answer your question. Sorry.
My guess is a typo. It is probably supposed to be 115200 baud, since USB 1.0 runs at 1.5MB/sec and USB 2.0 runs at 60MB/sec.
But, we all know what assuming does.... it makes an A$$ out of you and you.... or something like that
So no one has tried sending text to the OSD, eh?
Now, we just have to hope that their definition of control ports matches with ours
P.S.
Here is the whole article: http://www.hometechnews.com/info/2006/01/04/122600.html
Looks like the Axcent2's ports topped out at 38.4, so you'd be outta luck there - unless you attached an AXB-232++.
- Chip
Not to worry?
Whats 200 baud among friends?
There has not yet been a document officially released for the H20.
People often forget the comma in 115,200... it must be there!
Are you sure about that? I just coincidentally changed my HomeWorks to 115,200 after installing an IP/232 link (old processor) and tried that with the comma and it didn't work. Remove the comma and it worked perfect. Seems to me those strings are comma delimited and the Netlinxs processor would think the 200 was the next value in the string and not a continuation of the baud rate.
I have the H20 connected to an Axcent 3 serial port as I described in my post. The Axcent 3 absolutely wants the comma. I went into notifications for the device and tried it both with and without the comma followed by GET_BAUDs and it only changes with the comma.
I'm considering using this and I want to know that someone else has done it before I order the adapters and RS232 cards I'll need. A lot of our clients have H10-250s.
Do you mean the HR10-250 Directv TiVo ? If so then no, the TiVo units do not have any form of serial control, only IR. The HR10-250 is a TiVo unit and the box is made by TiVo/Hughes and sold by Directv. TiVo as never installed any form a 2-way control (that I know of) into any of their boxes. Only the new Directv(non-TiVo) units have this serial/USB control.
Also, I have tried these commands on a HR20-700 Directv HD DVR (non-TiVo) and the commands do not work. Last I heard from the Directv Reps the RS-232 will be added to the HR20-700 early next year. No changes to the HR10-250 are planned at the moment.
I wish the HR10-250 did have serial control. I have never found any evidence of control and the TiVo Rep at the CEDIA show told me that RS-232/IP control was low on their todo list.
I hope this helps.
Wow, my heart sunk when I read this post, because we have a client with several HR10-250s. But I suppose it's better to find out now than after we order the adapters and the extra RS232 card. Thanks.
I thought I would mention that we have been using the Hawking Technologies HUC232S USB to Serial Converter with the DirecTV H20 and it also works fine, so I'm sure there are other models of converters that work also, not just the three mentioned at the outset.
Eric
I'm using the IO Gear GUC232A and NI700 at 9600,n,8,1. (115,200 yields no RX)
When sending commands, I do get respsonses from the STB, but the STB doesn't actually do anything. For example:
Send "$FA,$81" //standby
Receive F0,0 //unit stays on
Send "$FA,$82" //active (on)
Receive F0,0 //no change to unit status
Send "FA,$87" //get current channel
Receive F0,6 //same rx no matter what channel it's on
Otherwise try this, unplug the USB adapter and then unplug the Power, then plug the power in, then when you have video, plug the USB adapter back in. I have only had to do this the first time I use a reciever, after the reciever sees the USB adapter everything seems work just fine.
Hope this helps.
Pauld
It all works. I have multiple installed. I use the IOGear GUC232A USB adaptor. Set the Baud for 115,200. Here's all the cmds. You need the CR on the status cmds. I don't think the tuning string (tune_chan cmd) worked on the H20 so I use the individual number commands and send them one at a time. It all runs thru a cmd queue at 500ms and all seems happy
I also query for the channel every 3 secs or so and that works fine. I'm pretty sure I tested all these. Use at your own risk.
Merry Chwanzaka.
