What maximum quantity IP of devices may control NI-700?
Hi!
Prompt please who knows.
  • The Netlinx Master allows 200 IP connections at the same time.
    This includes also Studio, Modero panels.
  • YuriyYuriy Posts: 20
    Thank you!
  • travistravis Posts: 180
    Is this still the case on newer masters? I just tried 199 TCP client modules, and they connect, but they don't send text t o the server. Any way to change the limit? I have memory left and CPU left.
    I could very carefully orchestrate which modules are online at one time, but that will be a lot of extra work and it seems like opening and closing connections uses a non-trivial amount of CPU.
    If you stagger the connection openings, you can hold more devices online at the same time. I have safely held 60 non-chatty devices open at the same time from an NI-700.
