Meeting Manager
Hello everyone
Here is a question about MM. I know that you can use it to monitor all the different devices in a system and check to make sure they are still responding to the master. My question is, can the sample rate be changed? The reason is that some projectors will not respond during the 'warm up' period and they might show up as 'offline' or 'not comm' with MM; which would or could trigger a false alarm.
Yes, there are two ways, use RMS CodeCrafter and within the Edit Monitored Device wizard, you can change the value or using NetLinx code, use the Send_Command to the device module 'COMM TO-[DPS],[Timeout]'.
