Insering AXC cards online?
Hi there,
Anyone know if AXC-... cards can be inserted online into an AXCESS CardFrame without turning power off, and if yes, if the newly inserted cards would be recognised by the system (i.e. "show device") without rebooting the cardframe?
Bob
Bob
1. Remove all static electricity by grounding yourself.
2. Hold the card by the tab end and slide the card into the frame, into one of the slots. Make sure
the card is correctly positioned in the guide slot.
3. Gently push the card in until it is firmly seated in the card connector slot. You do not have to
disconnect the power to the CardFrame when you install the card. When power is applied to
the card, the LEDs blink to indicate the connection.
Yes, they are hot-swappable. Don't know about the reboot, it's been a long time. HTH.
WAIT 10 'CHECK ONCE A SECOND'
DEVICE_NOW = DEVICE_ID(AXC_CARD)
IF (DEVICE_NOW <> DEVICE_OLD)
DEVICE_OLD = DEVICE_NOW
(* OTHER ACTIONS HERE *)
A new card will automatically be regognised, no need for anything "special".
Be careful hot-swapping relay and voltage card though - you can greatly affect the devices connected on those, and they can affect the card as well.
