Wireless Axlink?
mush
in AMX Hardware
G'day, Thanks for looking.
I have an application that requires connecting Axlink between two buildings.
To run a cable would be extremely difficult and cost prohibitive.
Has anyone ever run Axlink wirelessly?
Does anyone have any ideas as to how I could do this?
Any help or ideas much appreciated.
Cheers
Cheers
You could also use perhaps AXB-NET (that allowed you to transport AXLInk though Ethernet) if you have an ethernet network, and these boxes are defunct since shorter time than others, so greater chances to find some
Hope it helps
Vinc
--D
Here is the link, hope that it works:
http://www.aerocomm.com/rf_data_modems/connexlink_radio_modem.htm
Nice suggestion as Aerocomm was chipset used by AMX for wireless link in AXLink devices in past
Vinc
Vincen, I presume you are refering to a Wave server and a WAV-PK?
Do you know if this will actually extend Axlink, as from what I've
read about these it appears that only one device number will work
on the WAv-PK end. Is this correct? I've not had any experience
with these units so any advice from those that have experience
would be much appreciated. I've been keeping my eye open for these
on eBay but they are few and far between.
The other suggestion to use the aerocomm is a good one but I have
a question. Is the Axlink bus two simplex or duplex lines?
If they are duplex then using a aerocomm is not going to work off
the shelf as far as I can see. Once again any comments or
suggestions appreciated.
Cheers
Matthew
In fact it's a WAV-LNK and it supports up to 16 AXLink devices connected to it
Vinc
The mentioned Aerocomm tranceivers (900Mhz/2.4GHz) could provide a "complete" solution (interface and transmission).
An other option could be to use a RS-232 to Ethernet converter like those made by Lantronix, Digi and others and use the (existing?) LAN.
I would not recommend the AXB-NET devices - I was told by several at AMX that those never were reliable.
Thanks Mate! I will keep a lookout for these on eBay.
Thank you too Wilbert!
After reading your post I remembered an old tech note which turned out to be TN29. http://www.amx.com/techsupport/PDNTechNote.asp?id=29
It would appear that you are correct, Axlinx is a 'type' of RS485 and 20.8K is strange. So I think your idea will work. I will check it out.
Thanks again.
Matthew
