About Sharp LC-32G4T LCD TV???
Dearall,
I tried many ways to control it,but.......fail,fail,and fail
When the TV is in 'off' state(orange light), all of the commands is not working, and there's no response back
Otherwise, when the TV is in 'on' state(green light), all of the commands is still not working, but there's response back 'ERR'(just only this one)
Should I mention other things?or.......
What is your protocol and what is your com port set to?
As for the ERR messages, you may have to experiment with it a bit with a terminal connection to see what works. Sharp has not ever been very consistent from model to model ... some need extra zeros in the parameter, some use spaces; but the command itself is generally the same. Also, I have noticed on some, you get an ERR message when you try to switch it to a state it's already in. I've attached a rough module I have used successfully, see how it goes for you.
After tuned power saving mode off.
the control is OK.
Thanks again.
