Netlinx Diagnostics and text searching
                    Had a day yesterday where I all but gave up trusting Notifications . Very frustrating. Does anyone else ever use it? I was literally seeing *some* button presses reported but not others. For some reason it often reported button 1001 as being pressed, and I didn't even have a button 1001. With strings to and from selected for all devices, I still wasn't seeing everything, but then if I added a line to watch strings to and from a particular device, suddenly they'd appear. Why can't this be fixed? And why can't you watch strings to/from IP devices? I was in a situation where I couldn't watch the front of the NXI to see rx and tx activity, and realized how limiting this was - unable to trust this diagnostic tool at all. Grrrrrr.
Also, when are they going to fix text searching?? The latest NS release still has the same problem. It fails to find anything the first time more than half the time. Close the box and do the search again and suddenly it finds stuff. If you inherit someone else's work, the ONLY way to trace what a particular button does is knowing the channel number, then searching for instances of it (and you can't look for [TP,x] because x might already be declared within a button array). Those of us who also work on the other side know the power of F2.
OP
OP
