Optoma H56a 232
Hello, I'm Trying to control a H56a using the 232 port, the people from optoma said that the protocol is the same, but I'm not able to power on, if I switch it on manually every commands works fine except the power on.
Any idea.
thanks.
  • I just had the exact same problem with a projector.
    Turned out the device I was working with needed to steal power
    from the NI **only when it was turned off**. So, the
    effect was that with a 3 wire cable (RX, TX, GND) everything
    worked except the 'power on' command. When I used a 5 wire cable (added RTS and CTS) the power on command started working.
    The other thing I've seen with projectors is a menu setting for
    power saving or something similar, which if not set properly disables the control port.
    Hope that helps.
  • Optoma 232
    Hi, finailly I found a way to control it.
    To power on set thge baud to 9600 and send "'OKOKOKOKOK',10,13"
    The rest of the commands at 57600.
    And now it's working.
    Re: Optoma 232
    Good thing you're not programming on that C
    platform, eh? (No baud rate change after compilation)
    - Chip
  • What do you mean?
    If before send the power on command I set the baudrate to 9600 it's works perefect and after that I setup the baudrate to 57600.
