A Question about Button Events...
Hello All,
I wonder if I can have the external LEDs on a MVP8400 flash anytime a Button is pressed on the TP. So my question is, can I have 2 different button events pointing to the same button and have both execute everytime a button is pressed? Or do I have to make it work with just 1 Button Event?
for example.
Will this work?
for example.
BUTTON_EVENT[dvTP1,0]
PUSH:
//PULSE THE EXTERNAL LEDs HERE
BUTTON_EVENT[dvTP1,6]
PUSH:
//DO SOMETHING
Will this work?
If there are no PUSH or RELEASE statements in mainline, you are OK, but I wanted you to know of this behavior when using the global event handler.
Have you tryed to make a button array?
Something like this:
DEFINE_CONSTANT
INTEGER BUTTONS[]={1,2}
DEFINE_EVENT
BUTTON_EVENT[dv_PANELS,BUTTONS]
PUSH:
TO[BUTTON.INPUT] // AS WE HOLD THE BUTTON PUT IT ON
SWITCH(GET_LAST(BUTTONS))
CASE 1:
// DO SOMETHING
CASE 2:
// DO SOMETHING
Good luck
I did think about that, but in this case I believe the general Button Event is the most efficent way of doing what I need to.
Thanks for all the ideas everybody!
