Viewstat with Humidity Experience
TurnipTruck
in AMX Hardware
Greetings,
I am putting together a system with Viewstats. The project requires humidity sensors on some of them. Having never used Viewstats with humidity sensors, I am leary because the Netlinx module documentation says that humidity sensors can prevent the Viewstat from showing the current temperature.
Could someone please explain this to me?
If the Viewstat cannot display the temperature, nor allow you to manually arrow it up and down with a sensor attached, I will have to choose another stat for the project.
Thank you.
Thank you.
The rsr terminals on the viewstat are used for communicaton with remote modules.They are therefore sepparate from the 422 lines to controller
