Files open as Axcess Code..ARGH...
When I open up older netlinx files in studio, they are for some reason color coded like axcess files and things like // dont make stuff comments...It looks like everything opens like it is an axcess file...where do I fix this...it has to be a setting...also if you go to build - complie, it tries to compile it as axcess...have to do "compile as netlinx'
All of the files were originally coded in netlinx
Rolo
Rolo
This has caught me in the past and since then for all projects - even older single source file ones - I create a workspace. The workspace communication properties for the system override the default communication properties in netlinx. (plus it's good policy to use workspaces
(edited for clarity)
