Help Please - Netlinx Internal Diagnostics
RicardoSiqueira
in AMX Hardware
I am working in a system out of town and I keep getting this message when I ENABLE - 'Netlinx Internal Diagnostics Messages' under the Netlinx Studio Diagnostics menu:
The system includes 1 NI-4000, 6 MVP-8400s and 1 CV12. All panels IPs are static, as well as Master. Running latest Duet firmware on NI-4000 and all panels have their respective latest device firmware. Things are working, but I am worried about this message.
Any ideas. Is this something to be worried about?
Ricardo
Line 10 :: IPDeviceDetector.processDatagram(): missing DPD property - 17:56:29
Ricardo
nTmTsProtocol = nProtoSNTP
nTmTsCheckTime = 0
strTmTsServer = ''
Another thing that I just noticed this morning is that one of the MVP-8400 keeps dropping the connection. This may be related to a Cisco Access point malfunction. Any other ideas?
Ricardo
Hi Ricardo,
Did you find the solution to this problem? I realise it has been a while since you last posted in this thread but I am having the exact same issues you described in your opening post. System seems fine but the diagnostics keep throwing up the message "IPDeviceDetector.processDatagram(): missing DPD property" every 20 seconds or so. This doesnt seem to be causing any problems but as you said is quite worrying.
Also we are using 5 MVP-8400 on the job but it seems that every now and again (every 2-3 days it seems) that one of these will drop their connection to the master. The only way to correct this is by rebooting the panel after which it works fine again. Are these issues related and if so have you any recommendations?
Any help would be much appreciated.
Regards,
Shane
I have nothing to add for the original problem, but that exact touch panel issue I have seen. It turns out there was RF interference between the access point and the panel. It was less than 10' away, but there were some SOnos boxes right next to the access point that I wasn't aware had their WiFi on, and they were stepping on the signal. Even though I had an "excellent" signal strength, the panel would drop off line and stay off line until rebotted. I moved the access point and the problem went away. Funny thing, it is now actually farther from the panel than it was ... but it is also not right on top of the Sonos boxes.
That is interesting. It is hard to pin point exactly where in the house this is occoring as they tend to use the TPs in different rooms from time to time. However I have a sneaky suspicion that the problem could be with the panels when they are in the Playroom where they have an XBOX 360, PS3 and a Wii all within 15-20 ft of the WAP. It probably doesnt help that these consoles are never actually turned off!! I have just ordered Wi-Spy so that might give me a better idea where there could be an interference issue. Moving the WAP is'nt really an option but I might try plug it out and piggy back on the "Good" signal from the WAP in the room above. Thanks again for the help.
We are considering getting an RF Spectrum Analyzer for this very reason. As of now, we're split down the middle of whether to drop the $8K~$12k for it. I'm so ready to get one. I estimate we'll save at least that much in two months in useless service calls dealing with wireless issues that we do not get paid for.
I've been tracking it for about 6 months now and we easily spend thousands per month sending techs out dealing with this kind of stuff. A few more months of data and I'm sure I'll win the argument. (Then my plans for world domination can continue unabated ~ rubbing my hands together maniacally)
