Escient Fireball IR codes
Hi. Does anyone out there have an IR file that works with the Escient Fireball units? Some of the codes in the IR file AMX has on file do not work. I'd appreciate the assistance. Thanks.
Tim
Tim
Jeff,
I'm using an Axcess system and the Escient is one of the E-40/120 Fireball units.
Tim
Hope this helps,
I'm pretty sure I tried their IR file and it did not work for all the functions either. I'll give it a try to see if it's changed. Thanks.
Tim
Why don't you use RS232 control. It works fine but I am using Netlinx. You may have spend some time writing code to handle data coming and parsing them out but it seems to work fine
Kenny
I'm trying to control the Escient using a stand alone viewpoint without a control hub using IR. I'll try the IR code Escient had on their web site this weekend. I think we already tried that one but I can't say for sure. The IR file AMX had for this unit worked on some commands but commands like "page up, page down" didn't. Thanks for the help.
Tim
