Pace SkyHD Italia IR File
Yo Euro Guys,
I have some guys over in Europe and the are looking for the IR file for the new Sky Italia HD receiver. Any of you guys have it? You can PM me.
Make: Pace
Model:DS815NS
Andy
  • AM93AM93 Posts: 10
    In case anyone else is passing though Italy.
    Thanks to BobF at Amx and our Italian counterparts.
  • Thanks!
    Had trouble with learning this one recently. File worked well, although had to change the pulse times a bit to prevent double pulses.
  • Sky Italia Play,Record,Pause
    does anyone has the commands for (Play,Pause,Record) ?
    I have a Sky Italia remote but cant learn the codes with the AMX Iris capture Unit.
    Thats all i got so far:
    Carrier for a command in the Sky-HD-iPronto_DEF File is 38Khz
    If i learn a command trough Iris it says 41Khz.
    "GuidaTV" Command from the File (Working)
    0000 006b 0036 0000 0008 0023 0008 0032 0008 001d 0008 006c 0008 0032 0008 0032 0008 002d 0008 0022 0008 01f5 0008 0022 0008 0052 0008 001d 0008 001d 0008 0037 0008 001d 0008 001d 0008 001d 0008 0c07 0008 0022 0008 0032 0008 001d 0008 006c 0008 0032 0008 0032 0008 002d 0008 0022 0008 01f5 0008 0022 0008 0027 0008 0047 0008 001d 0008 0037 0008 001d 0008 001d 0008 001d 0008 0c07 0008 0022 0008 0032 0008 001d 0008 006c 0008 0032 0008 0032 0008 002d 0008 0022 0008 01f5 0008 0022 0008 0028 0008 0047 0008 001d 0008 0037 0008 001d 0008 001d 0008 001d 0008 0023
    "GuidaTV" command learnd trough Iris (not Working)
    0000 0065 000c 0012 0008 002b 0008 002b 0008 0021 0008 0073 0008 0035 0008 0035 0008 002b 0008 002b 0008 0212 0008 002b 0008 004e 0008 0021 0008 0021 0008 0035 0008 0021 0008 0021 0008 0021 0008 0d08 0008 002b 0008 002b 0008 0021 0008 0073 0008 0035 0008 0035 0008 002b 0008 002b 0008 0212 0008 002b 0008 002b 0008 004e
    Any suggestions or workarounds ?
    Thanks for your help.
    Manuel
