Dynamic Images, dynamic URL?
Is it possible to have a button with an image (jpg) where the URL itself changes? Basically I am getting back something like:
Artist=Billy Joel
Songname=Always a Woman to Me
Coverart=http://www.foo.com/coverart/billyjoel/album.jpg
How do I put that covertart on a G4 panel? It seems so simple, but all I know how to do is a dynamic image, not a dynamic URL!
Curt
Trikin
Artist=Billy Joel
Curt
Trikin
I tried to use the ^RMF commands recently for a camera switching app using an AXIS 241Q video server. Even though I was 100% certain I was putting in the path and file the way I had used it in the resource manager when I tested it, I could not get it to work. The test program is short, so I'll post it. I worked with Gary in Tech support, eventually he came up with a workaround using the ^BBR command, so its all good, but I would still like to know why the heck it didn't work the way I first tried it, or how you guys might suggest troubleshooting it. I kind of suspect something with the arguments at the end of the filename is hosing it, tried $3f for ?, samo for = , didn't get anywhere. Any insights much appreciated.
Bob Moyle
Thanks for the reply. The button I was using for the dynamic image had 'axis-cams(dynamic)' assigned to it.
Bob
You mentioned that you?re 100% certain of the file and path. How about the IP? You can embed it in your ^RMF command with %H.
'^RMF-axis-cams,%Aaxis-cgi/mjpg%Fvideo.cgi?camera=1&resolution=704x480'
I tried
"'^RMF-axis-cams,%Aaxis-cgi/mjpg%Fvideo.cgi',$3f,'camera',$3d,'1&resolution',$3d,'704x480'"
I didn't try sending the %P or %H values, they were already set correctly in the resource, my understanding of this command is you only modify the fields you need to.
thanks,
Bob Moyle
"'^RMF-axis-cams,%Aaxis-cgi/mjpg%Fvideo.cgi%3fcamera%3d1&resolution%3d704x480'"
That?s correct, I was just trying to cover all the bases.
I am having an issue with the ^RMF- command here is what I have but the image isn't updating any ideas?
TIA
tried it both ways but no luck the dynamic image is never updating
Not a stupid question my DHCP settings were not providing dns settings. I changed it to static. Will let you know if that fixes it
