How to send IR code via MVP-7500??
As title,
Can anyone help me solve this question??
In TPD4 go to "File>Project Properties>IR Emitters & Receiver".
Assign a port to the IR transmitter (above I used 13 on User IR 1 Channel Port). I didn't set anything in the DATA_EVENT, I don't remember why not. Map your IR file to the TP's xmitter port or just send the IR file directly.
I really don't recall anything else about setting this up but Software History should shed some light on the other port settings.
In your button config, go to the Program tab, then for channel port, choose "user IR port 1" and then you can assign a channel code to pulse the IR code
I Believe what Yuri said is correct and if you don't do any Netlinxs code and make the TP buttons match the IR xmit port and channel match the IR slot index you want to send it will probably work.
As with most things AMX, the instructions make perfect sense if you already know what you doing but if you don't they are vague and open to interpretation.
That's why this forum is so critcal, helping us figure out this stuff together and getting help from all those experienced programmers who probably have better thing to do but take time to help us any way!
Let us know how it works.
button channels need to match the IR channel number.
setup "IR port 1" for the TP to any port # you want. ie. 21. Then assign play button for example to be port 21, channel 1 (typically). load desired ir file to port 21on that TP. then your button will send the ir from mvp with no netlinx code. can do this for two IR files/devices. very nice workaround sometimes.
