Switching from AXCESS to Netlinx
in AMX Hardware
Hi everyone,
I am about to transfer an Axcess based system to NI-700 master. Anyone could give some ideas as to what the minimum program modification is and where to start? Any hints?
Bob.
Bob.
However you may want to move all your push statements to Button_Events.
Also, you will need to create data_events for your RS232 devices b/c the startup section will not setup the ports anymore.
And I believe device addressing will now need to be in the D:P:S format.
I would also need on a Button_Event, to login to a remote (linux) server (to its IP address) and execute the "poweroff" command. Any Netlinx lines for doing that?
Bob
That will get you started, you can also do a search on this forum with some people having timeout issues with the port.
http://www.amx.com/techsupport/Programming%20FAQs/Converting%20AXCESS%20to%20NetLinx.pdf
A device defined as will be treated at compile time as if it said,
