Having problem with converted Axcess code to Netlinx code
Hi All,
I have converted axcess code to Netlinx code. It compiles as Netlinx fine. But when I connect my codec to a Panel and a controller i am getting Error Messgae: TImed Out from Codec:
This is totally new to me. I just started learning this amx stuff.
Any help would be great.
This is not a typical NetLinx debug message, so it seems to be generated by the program.
When converting AXcess to NetLinx code, the 2 most common things have to be modified:
1) device addressing
2) Setting the baudrates should be done in the ONLINE handler of a DATA_EVENT instead of doing this in DEFINE_START.
But both depends on how you have changed the hardware setup.
Hi New,
How about if you post the code and some details about what is connected to what?
Some of my code looks like this
DEFINE_DEVICE
CODEC = 1:1:0
ROOMCNTL =2:1:0
PANEL = 128:1:0
PANEL2= 129:1:0
PANEL3= 130:1:0
(* STARTUP CODE GOES BELOW *)
DEFINE_START (*OK3.0*)
SEND_COMMAND CODEC, 'SET BAUD 4800,N,8,1 485 DISABLE' (*3.1F*)
SEND_COMMAND CODEC, 'HSON'
SEND_COMMAND CODEC, 'RXON'
SEND_COMMAND ROOMCNTL, 'SET BAUD 9600,N,8,1 485 DISABLE'
#WARN 'CHANGE ROOM CONTROLLER SPEED SETTING HERE!' (* 3_1B!! *)
SEND_COMMAND ROOMCNTL, 'RXON'
(*SEND_COMMAND 3, 'SET BAUD 9600,N,8,1 485 DISABLE' (*FOR TEST PURPOSES*)
SEND_COMMAND 3, 'HSON'
SEND_BUF=''
SEND_FLAG=0
TIMEOUT=0
SEND_GO=1
RECEIVE_BUF =''
CODEC_BUF =''
CREATE_BUFFER CODEC, CODEC_BUF
____________
Also when i connect to Netlinx studio It shows the panel are connected but i don't see my codec connection at all. So what do you think the problem is?
Thanks for the help
DEFINE_DEVICE CODEC = 5001:1:0 DEFINE_EVENT DATA_EVENT[CODEC] { ONLINE: // if com port firmware is ready to operate { // add the comm parameter commands here } }Just a hint:
If you do a CREATE_BUFFER, the RXON is set automatically.
...but maybe more detailed
However I did not convert the code from Axcess, I wrote NetLinx code, using a comms engine refined over the last 5 years.
Here is the startup code I use, which differs from yours; I use the data_event.
send_command dDevice,'SET BAUD 9600, N, 8, 1 485 DISABLE'
send_command dDevice,'HSOFF'
send_command dDevice,'XOFF'
Do you send carriage returns on the end of your commands?
Have you tried connecting direct from your PC serial port?
Have you checked the device number?
If it still doesn't work feel free to private message me or Skype me (check timezones first please!) and we will sort it out together.
Be aware that the Tandberg spews masses of stuff at you if you turn on all of the options so the odd message you mention is no surprise.
New has sent me a show device from his NI700 and here it is, followed by the same from my good NI700. Can anyone shed any light on why the NI700 device is missing?
FAULTY NI700
00000 (00298)NI Master (00001)AMX Corp. 00341 v2.95.214
(PID=0:OID=0) Serial='210503xp0350099',0
Physical Address=IP 10.0.0.133
(00298)vxWorks Image (00001) 00339 v2.95.214
(PID=0:OID=1) Serial=N/A
(00298)BootROM (00001) 00340 v2.95.214
(PID=0:OID=2) Serial=N/A
(00256)AXLink I/F uContr(00001) 00270 v2.01.124
(PID=0:OID=3) Serial=0000000000000000
00128 (00188)COLOR LCD TOUCH PAN(00001)AMX Corp. 00002 v3.19e
GOOD NI700
00000 (00298)NI Master (00001)AMX Corp. 00341 v2.96.218
(PID=0:OID=0) Serial='210503p3540643',0,0
Physical Address=IP 192.168.0.100
(00256)AXLink I/F uContr(00001) 00270 v2.12.140
05001 (00286)NI-700 (00001)AMX Corp. 00346 v1.12.140
(PID=0:OID=0) Serial='N/A',0,0,0,0,0,0,0,0,0,
Physical Address=Internal Connection
Thanks for the help
Below is show device from Ni-700
Does this look good?
Device (ID)Model (ID)Mfg FWID Version
Physical Address=IP
(PID=0:OID=0) Serial=0000000000000000
Physical Address=Axlink
00129 (00188)COLOR LCD TOUCH PAN(00001)AMX Corp. 00002 v3.19e
05001 (00286)NI-700 (00001)AMX Corp. 00346 v1.01.124
Device 5001 has appeared. You should now find that your code cans end strings through the serial port - watch for a red led flash on the front of the controller. If the codec is responding you will see an answering yellow led flash.
Looks like old firmware in the faulty NI-700.
