Home AMX User Forum AMXForums Archive Threads AMX Applications and Solutions
How to change a button text?
I'm sorry for this stupid question...i've searched the forum and think i've found the solution but it doesn't work properly...
In tpd3 i assign to my button Variable text device and channel (same as channel code)
In NetlinxStudio i use this:
SEND_COMMAND vTP,"'@TXT',aBUTTON,ITOA(MATRIX_STATUS[TEMP])"
where aBUTTON is the channel code.
What's wrong with this?
  • mpullinmpullin Posts: 949
    What kind of panel is this? Also, aButton needs to be the button's address code, not the channel code.
  • lattanzilattanzi Posts: 22
    well, actually it is a web page...no panel...i'm using "save as html" tpd3 feature
    Can channel code be equal to variable text channel?
  • JustinCJustinC Posts: 74
    I am not 100% on this, but I don't think that command will work with the TPD3 Web control.
  • NMarkRobertsNMarkRoberts Posts: 455
    Use !T
    Browser touchpanels are meant to be identical to regular panels.
    They aren't perfect; for instance, if you use a transparent button face, the border on the LHS will be one pixel wider than the other sides.
    I use !T instead of @TXT and it works fine.
    Yes, the channel and vartext can be the same value. Only the vartext matters in this case.
    Thank you guys!
    Everything is fine now..both "!T" and "@TXT" work fine...the problem was just the ITOA function, I had to move it outside the send_command...don't know why
