Home AMX User Forum AMXForums Archive Threads AMX Applications and Solutions
How to grant access to a page?
Hi guys,
here is my situation: i'm using a web interface (tpd3 and saveas html feature...no tp), i have an "home page" with two buttons which redirects the user to other two pages. I'd like to grant acces to these target pages just to authorized users.
I'm thinking of creating a popup page, to be shown on the homepgae button click, with a keypad to insert the password, if the password is correct i close the popup and show the target page. How can i do it?
  • yuriyuri Posts: 861
    easy, done it before.
    you defined your webpanel in your DEFINE_DEVICE section right? Did you combine the two? this isnt necesarry, but it's just handy...
    in your touchpanel design, you can make a button a "keypad button". If you do this, and the user presses that button, a keypad pops up. When a user enters a code, and presses enter, a string is sent back to your netlinx frame. Do it like this:
    DATA_EVENT[dvWebpanel]
    STRING:
    IF(FIND_STRING(DATA.TEXT,'KEYP-',1))
    REMOVE_STRING(DATA.TEXT,'KEYP-',1)
    (* this is now the code the user entered *)
    cCode = DATA.TEXT
    then you can test that code against your own code, and when it matches, make the page flip, otherwise, send a text back to the touchpanel telling the user he isnt granted...
    Hope this helps you out, i can give you some better example if you want :)
  • lattanzilattanzi Posts: 22
    I thought about that but i don't want to use the keypad button...i'd like to create it by myself...can you make a more general example? Anyway the problem is how to make a page flip by code?
    If you can follow this data_event and look at the tpd4 file you should be able to figure it out. Don't get confused by the structures and create your own variable to replace them. This uses a method where the button generates a string that is somewhat old school but is a simple way to create your own keypad.
    DATA_EVENT [dvAC_TPArray]
        STRING:
    	if (length_string(data.text))
    	    stack_var nAC_Datadev
    	    for (nAC_Datadev = 1; nAC_Datadev <= length_array(dvAC_TPArray); nAC_Datadev ++)
    		if (data.device == dvAC_TPArray[nAC_Datadev])
    		    nAC_ActiveRoom = nAC_Datadev
    	    Select
    		Active (find_string(data.text, 'KPD=',1)):
    		    remove_string (DATA.TEXT, 'KPD=', 1)
    		    cancel_wait 'ValidateWait'
    		    wait 40 'ValidateWait'
    			cAC_Pword = ''
    			cAC_FakePword = ''
    			send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',120 ,cAC_FakePword"
    		    select
    			ACTIVE (DATA.TEXT >= '0' && DATA.TEXT <= '9'):
    			    cAC_Pword = "cAC_Pword, DATA.TEXT"
    			    cAC_FakePword = "cAC_FakePword, '*'"
    		Active (find_string(data.text, 'KPT=',1)):
    		    remove_string (DATA.TEXT, 'KPT=', 1)
    		    Select
    			ACTIVE (DATA.TEXT == 'Back'):
    			    IF (cAC_Pword > '')
    				SET_LENGTH_STRING (cAC_Pword, LENGTH_STRING (cAC_Pword) - 1)
    				SET_LENGTH_STRING (cAC_FakePword, LENGTH_STRING (cAC_FakePword) - 1)
    				SEND_COMMAND dvAC_TPArray[nAC_ActiveRoom],"'@TXT',120 ,cAC_FakePword"
    			ACTIVE (DATA.TEXT == 'Done'):
    			    stack_var integer i
    			    local_var integer nPinUser
    			    if (length_string (cAC_Pword) == 4)
    				for (i = 1; i <= length_array(cAC_SecPwordsArray); i ++)
    				    if (cAC_Pword == cAC_SecPwordsArray[i])
    					nPinUser = i
    					i = length_array(cAC_SecPwordsArray)+ 1
    				    else
    					nPinUser =  0
    				if (nPinUser)
    				    if (nAC_KProuter == 1)
    					AC_Room[nAC_ACtiveTP].AC_Secur = AC_Room[nAC_ActiveRoom].AC_Secur
    					AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecPword = cAC_Pword
    					AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecValidPword = 1
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',118,cAC_SecArmDisplayArray[AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecState]"
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',119,itoa(AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecPartition)"
    					call 'AC_SecurTimeSend'
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',45,cAlarmRepeat_Array [AC_Room[nAC_ACtiveTP].AC_Secur.AC_Repeat]"
    					if (timeline_active(TL_FB_Blink))
    					    timeline_kill(TL_FB_Blink)
    					off [dvAC_TPArray[nAC_ActiveRoom], 113]
    					on  [dvAC_TPArray[nAC_ActiveRoom], 119]
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',117,''"
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',116 ,'PIN verification successful  ',cPIN_NamesArray[nPinUser],' !'"
    					nAC_KProuter = 0
    					cAC_Pword = ''
    					cAC_FakePword = ''
    					wait 20
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',116 ,''"
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'PPOF-_ACkeypad'"
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'PPOF-AC_ClosePage'"
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'PPOF-_ACkeypaddisplay'"
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'PPON-AC_SecurSelect'"
    					    if (!AC_Room[nAC_ActiveRoom].AC_Secur.AC_Set)
    						timeline_create (TL_AC_Response,TL_AC_ResponseRuntime,4,timeline_relative,timeline_once)
    					    else
    						send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',116 ,'Welcome back ',cPIN_NamesArray[nPinUser],' !'"
    						wait 40
    				    else
    					send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',116,'PIN verification successful  ',cPIN_NamesArray[nPinUser],' !'"
    					cAC_Pword = ''
    					cAC_FakePword = ''
    					wait 40
    					    send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',116,''"
    				else
    				    send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',117,'Invalid Password !'"
    				    if (!timeline_active(TL_FB_Blink))
    					timeline_create(TL_FB_Blink,TL_FB_BlinkRuntime,1,timeline_absolute,timeline_repeat)
    				    send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',120 ,''"
    				    AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecValidPword = 0
    				    AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecPword = ''
    				    cAC_Pword = ''
    				    cAC_FakePword = ''
    			    else
    				send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',117,'PIN requires 4 digits!'"
    				cAC_Pword = ''
    				cAC_FakePword = ''
    			ACTIVE (DATA.TEXT == 'Clear'):
    			    cAC_Pword = ''
    			    cAC_FakePword = ''
    			    AC_Room[nAC_ACtiveTP].AC_Secur.AC_SecPword = '0'
    			ACTIVE (DATA.TEXT == 'Abort'):
    			    cAC_Pword = ''
    			    cAC_FakePword = ''
    			    off[dvAC_TPArray[nAC_ActiveRoom], 119]
    			    on [dvAC_TPArray[nAC_ActiveRoom], 113]
    			    send_command dvAC_TPArray[nAC_ActiveRoom],"'PPON-AC_ClosePage'"
    			    send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',117 ,'Enter PIN aborted!'"
    			    wait 40 'PauseToBlank'
    				send_command dvAC_TPArray[nAC_ActiveRoom],"'@TXT',117 ,''"
