Is $0D Not Valid for Carriage Return in G4?
Greetings,
I am working with a UI module written for G3 panels on G4 panels.
All is well except that in variable text windows $0D does nor yield a carriage return.
The following send command to a G4 does not carriage return between the time and date:
!T$01$0DMON AUG 28$0D09:08 PM$0D$0D
Any suggestions as to how to get the carriage return to work?
Thank you.
  • joelwjoelw Posts: 175
    Use $0A or 10 for a new line.
    The clue is in TPDesign. Modify some text in a text box, then press control enter, then some more text.
    The "unicode send command value" gets appended with s a $000A.
    If it's in a send_command to change the text, you can imbed a | character, and the panel will interpret it as a newline. This is valid for G3 and G4.
    DHawthorne wrote:
    you can imbed a | character.
    What is the keystroke for that character?
    Thanks!
    Thanks!
    It's the shift of '\' (note: it's not '/')
  • generally, in windows systems, CRLF is used for a break, in UNIX systems LF is used..
    when i send sth. to a Touchpanel from the system, I usually use CRLF, which is 13,10, or $0D,$0A
  • NMarkRobertsNMarkRoberts Posts: 455
    I note that my nice new MS keyboard shows the pipe character as a continuous vertical line while every other keyboard I ever used has a gap half way - "dash dash" but vertically.
  • yuriyuri Posts: 861
    i don't think thats keyboard related but font/OS related...
    Unless, of course, he's talking about the actual label on the keyboard button :). You could say, I guess, that it's the font used to label the button ...
