Invalid Panel Size when sending across WAN
Greetings,
I am trying to send a tp3 file across the internet to an AXT-MCP/PB panel.
When connecting it to a local system it transfers fine. When trying to send it through a remote system, Studio errors out with "Invalid Panel Size"
Any ideas?
Thank you.
Any ideas?
Thank you.
Another possibility is that your AXT-MCP/PB is asleep. I'm not terribly familar with that model but if you try to load to an VPT-CP, for example, you will get that error if it's not awake. Connect via terminal to the master, and send the panel a WAKEUP command first and see it that works.
