Finding a CR in a String
Greetings,
I have a string in which I need to replace $0D with $0A.
I am trying to locate the $0D with:
All I get is a 0 for nWHERE.
Any better suggestions for finding and replacing the CR?
nWHERE=FIND_STRING(cVBL_TEXT_TO_SEND,$0D,3)
Put quotes around any single character string to make it work properly:
nWHERE=FIND_STRING(cVBL_TEXT_TO_SEND,"$0D",3)
The function!
DEFINE_FUNCTION CHAR[2000] fnReplace(CHAR strSTR[], CHAR strSEARCH[], CHAR strREPLACE[]) { STACK_VAR INTEGER nPOS STACK_VAR CHAR strTRASH[2000] STACK_VAR CHAR strTEMP_STR[2000] nPOS = FIND_STRING(strSTR, "strSEARCH", 1) IF (!nPOS) RETURN strSTR; WHILE (nPOS) { strTEMP_STR = "" IF (nPOS > 1) strTEMP_STR = LEFT_STRING(strSTR, nPOS - 1) strTRASH = REMOVE_STRING(strSTR, "strTEMP_STR, strSEARCH", 1) strSTR = "strTEMP_STR, strREPLACE, strSTR" nPOS = FIND_STRING(strSTR, "strSEARCH", nPOS + LENGTH_STRING(strREPLACE)) } RETURN strSTR; }Line to invoke the function.
>>In case you don't have the function, this is one that Dave got from the functions.axi file that kickin about.<<
Sounds like that could be a very useful file to have. Where could I get it? Or could someone email that file to me? I NEVER like to re-invent wheels...
Bill Querry
bquerry@crescentdigital.com
Crescent Digital, LLC
Check out the following Tech Notes for some useful string functions:
TN659 - TRIM_STRING
TN660 - FIND_STRING_REV
TN661 - REPLACE_STRING
TN662 - SPLIT_STRING
This particular function is all Leon
