Where can I buy the mini-phoenix plugs?
Can't find anywhere on the net (UK) that sells the 8 pin mini connectors. I stupidly threw out the NI3000 packaging with the connectors still in there!
Any ideas where I can buy them?
  • mini-phoenix
    Call factory. There is an FG # for each of the connectors, for example the 2-conductor is 41-5025 (I think). Pricing is by how many conductors for that connector.
    Have not found another source that sells in normal quantities.
  • You can get them from Newark (www.newark.com). They're a different brand, but work just the same.
    --D
  • You can also use the phoenix connectors from extron. They are the same size.
    Phoenix or mini-phoenix connectors are something of a standard conector type these days. The only compatibilty issue I have ever run across with them though, is the spacing of the contacts. They seem to come in configurations that differ by only 100th's of an inch; I have a batch from another manufacturer (now defunct) that I thought to use as spares for NetLinx jobs, but they won't go in - you can force a two-connector version in, but any more than that and the cumulative spacing difference makes them unuseable.
