Control of Yamaha 01V96
Hello all,
As you may or may not know, the yamaha 01v digital mixer has upgraded a to a new product called the 01v96 (96Khz sampling). Unfortunately yamaha also decided to drop the rs232 interface in favour of a USB connector.
Does anyone have experience in controlling the new mixer (maybe by some sort of USB-serial converter) or is MIDI the only way to go now?
And if so does anyone know of a good microphone/line mixer (at least 14 inputs) with fader automation and preset functionality which can be controlled by Netlinx?
Thanx !
Thanx !
We have encounter the problem in France and have found a solution. We use a RS232 port to control the 01V96 on the midi port. You have to wire the cable as explain below :
Midi RS232
Pin 4 >> TX - Pin 3 - With a 150 ohms resistence
Pin 5 >> Ground Pin 5
Pin 2 >> Non Connected
You have to do a SET BAUD 31250,N,8,1 on the RS232 port.
In this manier you can control the 01V96 as you do with old model.
WARNING : This is a one ways communication and just function with NI master (not with COM2 or NXI) due to the fact that you can set the port to 31250 speed on this equipment
Fabrice, ACE
Thx
Enjoy
Fabrice
any one has experiance in controling Yamaha 02Rvcm digital mixer
