Queue issue with nxc-vai4 and Nxc-rel10
Hi, i'm using two nxc-vai4 cards in nms boxs and rel10 card to switch on and graduate lights in a room. The user can change lights settings by pressing on two mio keypad and on two modero panels.
My issue today, is that changing lights setting for one light zone is quite hard for the systeme. i've to change the right Vai4 channel, and switch on or off the right rel10 output, and after that i've to refresh status on the two mio keypad and on the two modero panels. It's working quite good, with some "define_combine".
But when a user is "playing" with the system and puts all lights on and all lights off and all lights on again or recall a light preset etc... the system slows down and does things but slowly. It keeps in memory all the orders and does it one buy one.
I would like to erase the orders memory to keep only the last order in order to no slow down the system.
To drive vai4 card i'm using the send_command order and to change the rel10 status i'm using "on" "off" commands.
Is there a way to made it easyer?
thank you in advance !
math
