Login to an IP controlled device from Netlinx
 bob
bob
                    Hi there,
just starting with Netlinx and studying the following example it is not clear to me why the login and password to a controlled IP device is send as "login,password", i.e. with comma inbetween? Shouldn't this be CR or CRLF?
DATA_EVENT[dvCOMPUTER]
STRING:
SELECT // LOGIN REQUEST
ACTIVE (FIND_STRING(DATA.TEXT,'LOGIN:',1)): // REQUEST FOR USER NAME
// SEND_STRING dvCOMPUTER, "'login,password', $0D" // SEND USER NAME
STRING:
So in your example....
DATA_EVENT[dvCOMPUTER] { STRING: { SELECT // LOGIN REQUEST { ACTIVE (FIND_STRING(DATA.TEXT,'LOGIN:',1)): // REQUEST FOR USER NAME { SEND_STRING dvCOMPUTER, "'login,password',$0D,$0A" // Added a LF, $0A } } } }With the Added LF you should be ok.
-Trav
