MAX and Cisco
AMB
in MAX by AMX
Good afternoon!
Greetings from Russia.
There is a problem. The object on which MAX-MMS900M through switch Cisco Catalyst 2950 is connected with AVM modules. The problem that AVM modules cannot receive from MAX IP the address, at that if will connect AVM directly to a server AVM it is successfully loaded. Probably a problem in Cisco, tried to adjust, without successful. Who can that collided. Prompt please.
Did you note that the MMS900 actually has two network ports? One is strictly for control, and the other is strictly for media streaming. They have different subnets. If you don't have them on two different physical networks, they at least should be partitioned. You also have to make sure your router isn't blocking that media subnet - it defaults to a 10.xxx.xxx.xxx IP range, while the control NIC defaults to a 192.168.xxx.xxx range.
If that part is OK, then you need to define the AVM modules on the server before it will see them. You can do this in WinMax or from a console on the server itself.
The MAX is doling out IP addresses, correct? So it really shouldn't be too particular on the switch? Heck, I can get a few streams going through the cheap wireless router which is at least entertaining...
Curt
Trikin
Curt
Trikin
Similarly, when I tested system at office, on a cheap hub - problems were not. And so, misters what to do......? Streams are divided, in Cisco has switched off DHCP server, has appropriated IP the address - 10.0.0.201.
MAX - IP 192.168.1.20
