ADA TuneSuite with ISO-CAT II
in AMX Hardware
Was wondering if someone could verify the rs232 pinout for the ada-tunesuite with ISO-CAT II
Is this correct :
Thanks in advance
Is this correct :
Female -- Male [1] GND -- [5] GND [2] RX -- [3] TX [3] TX -- [2] RX
Thanks in advance
- Chip
codigo de ipod con equipo ADA - Free download as PDF File (.pdf), Text File (.txt) or read ... When using an ISO-E (ADA Bus to Ethernet), ISO-CAT-II (ADA Bus to ... PC/CS Cinema MII PC/CS WH (ada) Aquarius Tune Suite Aquarius ISO/CS
