Front button setup access code
Hi,
is it possible to have a passcode to enable users to get into setup mode using the front button? I've tried to set a password in the panel, which didnt work.
Offcourse i can make a button on the TP with a code attached to it, but the customer wants to use the big button on the front :)
  • yuriyuri Posts: 861
    hmm, i forgot to post the type of the touchpanel im talking about :)
    It's a CV7, so im talking about the big button (light sensor) in the middle of the panel :)
  • After I asked Yuri for clarification on this and went and looked at the manual I find that it says all about how you can read the light level from the "button" and refers to a nonexistent page in the manual, and no amount of searching helps... hhhmmmm!
    nope, and when you use the "show external buttons" in TP4, you can program the external buttons, but not the light sensor button...
