2.5 mm ViewPoint to PC programming cable
Anyone have the pin out or a source for this cable?
Panja VPT-CP programming cable.
Thanks giving!
  • yuriyuri Posts: 861
    uh, they come with the panel itself? :p
    i only use the "molded" type, so i have NO idea what the pinout is :)
    i could send you one, but since im in the netherlands that's probably not a good idea ;)
  • trobertstroberts Posts: 228
    when connecting directly to a computer, pins 2 and 3 are swapped, but the actual pin out of the cable that comes with the panel is:
    2 - tip
    3 - ring
    5 - sleeve.
    Good heavens, I must have thrown away dozens of them, and still have 3-4 kicking around. They came with the Viewpoint panels, and if you worked a lot with them (as I did), they became like those cheesy audio cables that come with stereo components: throwaways.
    I apparently threw away one two many of those suckers. I found myself at a loss for one (and cursing up a storm) when I encountered a 3G Viewpoint at a client's place. Of all the crud in my laptop bag - I swore I used to have two or three of those. I must have done some "weeding" and not paid attention to how many I removed!
    - Chip
  • JoeJoe Posts: 99
    It seems like the more of something you have, the more careless you are concered with keeping track of it. Guess how many Extron tweakers I've lost?
    Haha, indeed, i always have one with me, but i can never find it :O
