G4 Web Control ? Max # of Connections
In the G4 Web Control settings under Protected Setup there is a field for Max Number of Connections and it is set to 1. How do I change it to a number > 1?
Vinc
If I recall (I could just pull it up, but..) there is a setting in the property admin section of the VNC which allows you to choose the number of simultaneous connections to allow. I believe this is true of REAL and ULTRA which are the only ones I've played with.
The TPs should also be capable if AMX chooses. At least one would think!
