Problems for Start up of NXC I/O10
Dear all,
I am using a NXC-I/O 10 in a Card Frame, and I want it work turning on/ off relays.
First, I left the configuration of the switches on the board for : VO (voltage mode) and the Voltage Clamp Jumper for Open mode. The result was that I had no control of the port when I tried to turn on/off it.
Later, I changed the configuration of the switches on the board for: VO and +12 V to the Voltage Clamp Jumper. The result was that I had truly the control, but the voltage of the port was 0.5 V to the "1" state and 5 V to the "0" state.
I need the port work with +12 V in when set and 0 V when in "0" state.
Can someone help me?
Thank you in advance
