NS 2.5.0.163 Causing Hihg CPU Usage after Shutdown
TurnipTruck
Greetings,
I have been noticing that after opening, using, then closing Studio that my PCs CPU usage will hang around 60% until I reboot the PC. Before starting studio, usage is close to zero, as expected.
PC is a P4 running XP SP2, with a fresh Windows install.
Any similar experiences or suggestions?
Thank you.
Thank you.
I haven't tested this theory..but...
..is it related to the disconnection issue we KNOW exists with TPD4? ...that is if the connection to the master you have with TPD4 is terminated by, say, a reboot, your pc processor will spin at 100% until you remove the little box in TPD4 that alerts you to the disconnection.
Perhaps something of a similar nature in NSX?
Just a thought - might try some stuff later
Not specifically. But I will make sure to close all comm next time. Good idea.
Don't just close all the windows that initiate communications, use the button under Settings that stops it dead. Sometimes Studio leaves things running.
