NXP-TPI/4 + Samsung SyncMaster 173VT
I have one problem with my TPI4 interface. When I connect Samsung SM 757nf (CRT) or SM 172vt (LCD) monitor to TPI?s RGB output ? that?s OK, but when I connect Samsung 173vt (LCD with touch screen) monitor, I can?t see the picture on it or rather it is blinking. What you think about that. Maybe it is problem in frequencies synchronization?
Thank you.
  • Your TPI may be putting out a signal that's borderline out of range for that display - maybe try a lower resolution and/or refresh rate?
    - Chip
