OFFing an Array of Buttons
I would like to do something like this as a means of mutual exclusivity for the sake of feedback:
However this does not work. Does anyone have a suggested alternative for a one-line button-feedback-array killer? I don't want to define as mutually exclusive.
Thanks!
INTEGER cnFEEDBACKS[10]={1,2,3,4,5,6,7,8,9,10}
OFF [dvTP,cnFEEDBCAKS]
Thanks!
The following function seems to work::
define_function funBtnArrayKill(dev dvDevice,integer nArrayIn[]) { stack_var integer i for(i = 1; i < length_array(nArrayIn) +1; i++) { off[dvDevice,nArrayIn[i]] } }DEFINE_DEVICE dvTPSwitcher = 10001:1:0 ; dvSwitcher = 5001:1:0 ; DEFINE_FUNCTION fnHandleSwitcherBtnFBack(INTEGER iStartingINdex,INTEGER iBtn) { stack_var integer i ; for (i = iStartingINdex ; i <= iStartingINdex + 7 ; i ++)//handle feedback { if (iBtn == i) { ON [dvTPSwitcher,nSwitcherBtnArry[i]] ; } else { OFF [dvTPSwitcher,nSwitcherBtnArry[i]] ; } } } DEFINE_VARIABLE volatile integer nSwitcherBtnArry[] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17} ; BUTTON_EVENT [dvTPSwitcher,nSwitcherBtnArry] { PUSH: { stack_var integer nSwitcherIN ; stack_var integer nSwitcherOUT ; stack_var integer nBtn ; nBtn = get_last(nSwitcherBtnArry) ; Select { ACTIVE (nBtn >= 1 && nBtn <= 8)://select switcher input { nSwitcherIN = nBtn ; fnHandleSwitcherBtnFBack(1,nBtn) } ACTIVE (nBtn >= 9 && nBtn <= 16)://select switcher output { nSwitcherOUT = nBtn ; fnHandleSwitcherBtnFBack(9,nBtn) } ACTIVE (nBtn == 17)://take in & out { TO [dvTPSwitcher,nSwitcherBtnArry[17]] ; send_string dvSwitcher,"ITOA(nSwitcherIN),'*',ITOA(nSwitcherOUT),'!',13,10" ; } } } }DEVCHAN dcFeedback[] = {{device,1}, {device,2}, {device,3}, {device,4}} OFF[dcFeedback]--D
That will work, but I don't like DEVCHANs. I just array the button channel numbers and reference the array. Makes for less code.
