ZigBee?
Hi, I have been reading up on zigbee and it sounds very interesting and an ideal solution for retrofitting homes.
Has anybody taken a look at the zigbee enabled products and integrated into an AMX system?
Cheers
Phil
  • I haven't yet but too am also interested not only for clients homes but my own.
  • the8thstthe8thst Posts: 470
    I have a few R4 kits on order and they should ship in a few weeks.
    I will let you know how they worked out after I have a chance to play with one of them.
    I've been trying to get my hands on those for months. I think AMX made a mistake announcing them and should have held off a bit until they were more likely to be released. My sales people gave up on the last project they thought they could be used on, and came up with a alternative; now it looks like they might stick with that solution for future sales rather than have to deal with more potential delays. It's a bad precedent pitching a product and not having it when promised, it tends to make people not trust you with any subsequent releases.
    I put in an order for a two of the remotes just to have something in the queu for when they are released.
    I have one two projects that I have pitched the R4's, but these projects won't be ready for any equipment until June at the earliest. I also made sure the client signed an aggreement that the remotes may be substituted for a different product or the client my have to upgrade of the remotes will not do everything I think they should be capable of accomplishing.
    I just like to get new toys right when they are released, so as long as I have a potential project, I order well in advance sometimes.
  • mritzmritz Posts: 22
    Zigbee tech question
    Hello guys, I have a technical question about the amx zigbee gateway. I want to use a wireless zigbee motion detector to "trigger" a show-start generated with an amx master. Is this possible to do with the amx zigbee gateway?
    regards, Markus
  • vincenvincen Posts: 526
    It doesn't look difficult if your motion detector can be controlled through TCP/IP with a protocol ;)
    Vinc
