PTI card programing
in AMX Hardware
Does anyone have experience with PTI cards I am trying to do a simple system with two motors and pots. I simply want to move the motors from one position to another. Not rocket science. When I use the send_command 1, ?G1L2452? I get a light in channel 1 for a few seconds and no movement on the motor. I have used a create_level in startup so I can see the pot return and all seems well there. I have spent the last 4 hours checking wiring and code. I am at a loss. Can anyone help?
Do you have one hooked up?
I suggest hooking a multimeter to your power output instead of the motor, that way you can monitor voltage and see if the card is even working properly before trying with the actual motor.
