Bug/Caveat? ITOA() and negative SINTEGER CONSTANT
What?s a little sign bit between friends?
Consider the following code:
Output when button 1 is pushed:
Line 1 :: ITOA(snNeg275Const) = 65261 - 3:33:20
Line 2 :: ITOA(snNeg275Var) = -275 - 03:33:20
Output when button 2 is pushed:
Line 3 :: ITOA(NegConstPassedIn) = -275 - 03:33:23
ITOA() does not return negative numbers correctly when working on a SINTEGER CONSTANT as shown when button 1 is pushed.
However, if you pass the same SINTEGER CONSTANT into a function then ITOA() does return correctly as shown when button 2 is pushed.
Smells like a bug to me.
Reference:
DEFINE_DEVICE dvTP = 10001:1:0 DEFINE_CONSTANT SINTEGER snNeg275Const = -275 DEFINE_VARIABLE SINTEGER snNeg275Var = -275 DEFINE_FUNCTION fnITOASignedConst (SINTEGER NegConstPassedIn) { SEND_STRING 0, "'ITOA(NegConstPassedIn) = ',ITOA(NegConstPassedIn)" } DEFINE_EVENT BUTTON_EVENT[dvTP,1] { PUSH: { SEND_STRING 0, "'ITOA(snNeg275Const) = ',ITOA(snNeg275Const)" SEND_STRING 0, "'ITOA(snNeg275Var) = ',ITOA(snNeg275Var)" } } BUTTON_EVENT[dvTP,2] { PUSH: { fnITOASignedConst(snNeg275Const) } }
Reference:
Netlinx Help File wrote:ITOA
Converts a 32-bit signed integer to a decimal ASCII string. The syntax:
CHAR[ ] ITOA (LONG Num)
Parameters:
Num - a 32-bit signed integer to convert to a decimal string.
Result:
A character string that contains the decimal representation of the specified integer.
Example:
STRING = ITOA(501) // STRING = '501'
To quote one of my friends at AMX, "why would you want to do that!"
Looks like the constant is converted to a variable as it is passed into the function.
Joe, send this link GM.
I think it's interesting, if obvious, that
65536 - 275 = 65261
so when displaying a negative constant it just subtracts the number from the maximum integer size (same thing that happens when you subtract a bigger non-signed integer from a smaller non-signed integer)
I'll pass it along as necessary.
Best thing for now is to work the issue as described in previous posts...
This is considered a "feature", not a bug, as one will should get expected results with integers, signed or unsigned. Per the NetLinx Keywords Help: "converts a 32-bit signed integer to convert to a decimal string".
This is why you can get -275 in one case and 65261 in the other. Internally the sign bit is not at $8000 - as you would expect if the data were actually using only 16 bits.
