I Schedule Timer Servers and Settings
TurnipTruck
Greetings,
Culd someone please recommend a time server and protocol setting for I schedule? I have had mixed results using the built-in list.
When setup at default, the message log does show some connection errors. Am I to assume they are normal as the system tries to select a server from its internal list?
use ASTRO_CLOCK
I agree with Vining that you need to make sure the DNS is connecting properly, but you also have to make sure your network isn't blocking the port. This is common on a lot of firewalls because some consider the port a security risk. I know that my NT Server firewall shut it down by default, and I had to open it up.
