Home AMX Design Tools
G3 webcontrol in NIX100
hi all:
I have G3 webcontrol question in NIX100. I used JRE v1.5.0_10-b03 to try, but it did not work. JRE did not find some class and didn't install Java applet. Did someone have solution to try?
  • mritzmritz Posts: 22
    Try to use the java runtime 1.4.2.x - I think the latest version on this is 1.4.2.13 - Someone told me that the G3 webcontrol only works with one of this versions. I used this on a NI-2100 without any problems.
    ___________
    Markus Ritz
    Mediasystem
    Austria
  • G3 Webcontrol on NIX100
    I am currently running a NI-3100 with Firmware Version 3.21.343
    Duet memory set to 7MB
    Internet Explorer 7
    Java Version 1.5.0_10-b03
    All is fine with G3 webcontrol on my system.
    Rex
  • As told before, recommended version of Java for G3 WebControl is J2SE v1.4.2_08 .. _13, because G3WC is based on Java 1.4
    On my PC I run G3WC on Java 1.5.0_03 without any problems, on other PCs here in the office it does not work. We have not found WHY it does or does not, but maybe first to install 1.4 and then 1.5?
  • Thanks a lot.
    I used JRE v1.5.0_10-b03 on NI3100, and G3 webpanel work without any question.
