Two question of meeting manager
                    hi all,
1, how to activate the meeting manager?
2, i can't set my admin password, when i load the admin web page, also can't login. why?
please give me some advice.
Thanks!
Thanks!
You would need to run the RMS Configuration Wizard on the Windows Server. Under "Services" Select Register and then Start. Under "System Settings" select "Administrator" and enter username and password.
thanks!
i had already do that, but, i still can't login by admin right.
and i had register the services. by the reply of amx, the meeting manager still haven't activate.
so, could u please give me other advise?
Could you tell me what language your server operating system is using?
The best method to troubleshoot this problem is through AMX tech support. They have the resources to help you verify and fix most problems.
