TP String Parsing Module
I am having a little trouble on where to go next on this module.
MODULE_NAME='TP String Parsing Mod'  (
								    DEV dv_SPM_TP,
								    CHAR c_SPM_CurPg[],
								    CHAR str_SPM_KPValue[],
								    CHAR str_SPM_KBValue[]
(* System Type : NetLinx                                   *)
(* REV HISTORY:                                            *)
(*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
DEFINE_DEVICE
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
(*               VARIABLE DEFINITIONS GO BELOW             *)
DEFINE_VARIABLE
CHAR str_SPM_TPBuffer[1000]
CHAR str_SPM_TPResponse[100]
CHAR str_SPM_Trash[100]
INTEGER n_SPM_TPButton
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
(* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
(* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
(*                STARTUP CODE GOES BELOW                  *)
DEFINE_START
CREATE_BUFFER dv_SPM_TP,str_SPM_TPBuffer
(*                THE EVENTS GO BELOW                      *)
DEFINE_EVENT
DATA_EVENT[dv_SPM_TP]
    STRING:
        str_SPM_TPResponse = REMOVE_STRING(str_SPM_TPBuffer,str_SPM_TPBuffer,1)
        SELECT
            ACTIVE(FIND_STRING(str_SPM_TPResponse,'PAGE-',1)):
                str_SPM_Trash = REMOVE_STRING(str_SPM_TPResponse,'PAGE-',1)
                c_SPM_CurPg = REMOVE_STRING(str_SPM_TPResponse,str_SPM_TPResponse,1)
            ACTIVE(FIND_STRING(str_SPM_TPResponse,'KEYP-',1)):
                str_SPM_TRASH = REMOVE_STRING(str_SPM_TPResponse,'KEYP-',1)
                str_SPM_KPValue = REMOVE_STRING(str_SPM_TPResponse,str_SPM_TPResponse,1)
            ACTIVE(FIND_STRING(str_SPM_TPResponse,'KEYB-',1)):
                str_SPM_TRASH = REMOVE_STRING(str_SPM_TPResponse,'KEYB-',1)
                str_SPM_KBValue = REMOVE_STRING(str_SPM_TPResponse,str_SPM_TPResponse,1)
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
Here are the lines needed to make this work
Define_Device
dvTP 128:1:0
Define_Variable
CHAR strTPMd[25]
CHAR strKPResp[10]
CHAR strKBResp[25]
CHAR strTPPg[25]
Define_Start
Define_Module 'TP String Parsing Mod' ModPrase (dvtp, strTPPg, strKPResp, strKBPResp)
The code uses the built in keypad and sends the variables to strKPResp fine but now what I am wanting to do is separate the strKPResp into 3 different variables so that I can use it with a satellite receiver.
Any help would be great
  • yuriyuri Posts: 861
    how is your string built?
    you can use left_string, mid_string or right_string. Check their syntax, they work pretty well...
  • ondrovicondrovic Posts: 217
    Thanks, that helped I have it now. To anyone that would like this to see how I did it just let me know and I will post the code.
    Thanks Yuri
