My first AMX program :)
Hi all!
I just finished my first program
I get the input output leds on the NI300 to turn on when pushing some buttons on the TP (8400)
but I don't see the leds of the port ...
also when I connecting to the controller vis web browser I can see any devide on the devices list...
can someone have a look if my program is missing somthing crusial?
thanks a lot!
PROGRAM_NAME='room_1_program'
(* System Type : NetLinx *)
(* REV HISTORY: *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
DEFINE_DEVICE
// my touch panel device
dvTP = 10001:1:0
// Denon DVD 2800 Device (controller:device:system)
dvDVD2800 = 5001:1:0
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
DVD_PLAY = 1
DVD_PAUSE = 2
DVD_NEXT = 3
DVD_PREV = 4
DVD_FAST_BACKWARD = 5
DVD_FAST_FORWARD = 6
DVD_STOP = 7
DVD_PLAY_IR = 1
DVD_PAUSE_IR = 3
DVD_NEXT_IR = 4
DVD_PREV_IR = 5
DVD_FAST_BACKWARD_IR = 6
DVD_FAST_FORWARD_IR = 7
DVD_STOP_IR = 2
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
DEFINE_VARIABLE
VOLATILE INTEGER nDVDBtns []=
DVD_PLAY,
DVD_PAUSE,
DVD_NEXT,
DVD_PREV,
DVD_FAST_BACKWARD,
DVD_FAST_FORWARD,
DVD_STOP
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
(* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
(* STARTUP CODE GOES BELOW *)
DEFINE_START
(* System Information Strings ******************************)
(* Use this section if there is a TP in the System! *)
SEND_COMMAND TP,"'!F',250,'1'"
SEND_COMMAND TP,"'TEXT250-',__NAME__"
SEND_COMMAND TP,"'!F',251,'1'"
SEND_COMMAND TP,"'TEXT251-',__FILE__,', ',S_DATE,', ',S_TIME"
SEND_COMMAND TP,"'!F',252,'1'"
SEND_COMMAND TP,"'TEXT252-',__VERSION__"
SEND_COMMAND TP,"'!F',253,'1'"
(* Must fill this (Master Ver) *)
SEND_COMMAND TP,'TEXT253-'
SEND_COMMAND TP,"'!F',254,'1'"
(* Must fill this (Panel File) *)
SEND_COMMAND TP,'TEXT254-'
SEND_COMMAND TP,"'!F',255,'1'"
(* Must fill this (Dealer Info) *)
SEND_COMMAND TP,'TEXT255-'
(* THE EVENTS GO BELOW *)
DEFINE_EVENT
BUTTON_EVENT[dvTP, nDVDBtns]
PUSH:
STACK_VAR INTEGER nBtnIndex
nBtnIndex = GET_LAST(nDVDBtns)
SWITCH(nBtnIndex)
CASE DVD_PLAY:
PULSE [dvDVD2800, DVD_PLAY_IR]
CASE DVD_PAUSE:
PULSE [dvDVD2800, DVD_PAUSE_IR]
CASE DVD_NEXT:
PULSE [dvDVD2800, DVD_NEXT_IR]
CASE DVD_PREV:
PULSE [dvDVD2800, DVD_PREV_IR]
CASE DVD_FAST_BACKWARD:
PULSE [dvDVD2800, DVD_FAST_BACKWARD_IR]
CASE DVD_FAST_FORWARD:
PULSE [dvDVD2800, DVD_FAST_FORWARD_IR]
CASE DVD_STOP:
PULSE [dvDVD2800, DVD_STOP_IR]
} // END OF - SWITCH
} // END OF - PUSH
} // END OF - button event MainSetup
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
thanks a lot!
(* REV HISTORY: *)
DEFINE_DEVICE
dvTP = 10001:1:0
DEFINE_CONSTANT
DVD_PLAY = 1
DVD_PAUSE = 2
DVD_NEXT = 3
DVD_PREV = 4
DVD_STOP = 7
DVD_PLAY_IR = 1
DVD_PAUSE_IR = 3
DVD_NEXT_IR = 4
DVD_PREV_IR = 5
DVD_STOP_IR = 2
DEFINE_TYPE
DEFINE_VARIABLE
DVD_PLAY,
DVD_PAUSE,
DVD_NEXT,
DVD_PREV,
DVD_FAST_BACKWARD,
DVD_FAST_FORWARD,
DVD_STOP
DEFINE_LATCHING
DEFINE_START
DEFINE_EVENT
PUSH:
SWITCH(nBtnIndex)
CASE DVD_PLAY:
CASE DVD_PAUSE:
CASE DVD_NEXT:
CASE DVD_PREV:
CASE DVD_STOP:
} // END OF - PUSH
DEFINE_PROGRAM
dvTP = 10001:1:0
your Device is a RS 232 not a IR Interface
dvDVD2800 = 5001:9:0
thats your first IR Interface..
Don't forget: Load your *.IRL File to the Device 5001:9:0
5001:1:0 is a serial port, not an IR port. So that probably won't be helping much.
Try changeing your port to
If it is a 2XXX series, ports 5-8
or if its a 4XXX/3XXX ports 9-16 are the IR ports
A 700's IR port is port 3 and a 900 is ports 2-4,
Don't forget to upload an IR file to the port first !
Good Luck
now it working!
thanks guys
ady
Always use SEND_COMMAND with SP, or XCH (Very useful for control of cable or sat boxes), and set up each port with a SEND_COMMAND CTON and CTOF in online of each IR Port
Vinc
