Home AMX Control Products
WDS Undock command
Hello,
I was wondering if there is a undock send command ?
I'm using a card reader for checking the undock rights of the user.
I could not find the command... Maybee someone knows it?
Othewise I've to make make and remove users and password form the master.
    If you can't find a SEND_COMMAND you could do a "DO_PUSH" of the "Undock Panel" panel button in protected set up. Or create your own button in properties>channel port = 0-setup port. Channel code >advanced>docking>undock.
  • yuriyuri Posts: 861
    what i have done once is change the user/pass for undocking, so after a specific time, the panel can only be undocked with a password (so the cleaning lady couldnt steal it ;) )
