DMS WakeUP!
Is there a way to defeat the need for the DMS keypads back light to come up to full brightness (fully awake) before it will accept a button push. This is very annoying and the back light should have nothing to do with the ability to push buttons although otherwise if you can't really see there's no way to activate the back light with out executing a button push. Catch 22. OK, is there a way to expedite the back light instead of the sluggish way it wakes up presently.
The solution we're using is to set the backlight timeout setting to 0. Go into the setup pages of the MIO DMS and change it (within "Display Settings). The problem with this is the screens are forever glowing brightly.... not a big problem, except for when the client wants to go to sleep. so i've added a button that sends a command to the MIO DMS to go to sleep.
hope this helps
mark
i have to say though that i'm not very impressed with the MIO DMS keypads. AMX can surely come up with a much nicer designed similar keypad cant they? Use better materials, cleaner design, please more style!!
