Structure References
I was just about to post a long list of code for timeline help, when I tried one last thing ... and of course it worked (at which point I taught my 3100 a whole new set of "special commands" that my wife won't let me use at home). You see, I have created a structure to store all things relative to a communication queue:
DEFINE_TYPE
STRUCTURE CommunicationQueue232
CHAR MessageQueue[10][15]
INTEGER WaitingForResponse
INTEGER LastMessagePointer
INTEGER QueueLength
LONG TimeLineID
... and then created a structure for each queue:
DEFINE_VARIABLE
CommunicationQueue232 Sony232
I was assigning the timeline ID in start, since I can't assign them in the variable section, with code such as:
Sony232.TimeLineID = 1
I was going crazy trying to create a timeline using that ID, because nothing was ever firing. However, when I created a LONG contstant:
LONG SonyTLID = 1
... and used that in my TIMELINE_CREATE statement (and in the TIMELINE_EVENT), it all worked fine.
So my question is, am I missing something? I thought that Netlinx could dereference (OK, it's not a pointer, but not sure of a better verb) a structure in functions and events as long as the component part was defined correctly (as LONG in this case). Is this a bug, an unintended feature, or something I'm missing? It's not a big deal, but I was going to try to functionalize some of my 232 logic into a module and liked the idea of having a structure to keep the relevant stuff together.
Dan
DEFINE_TYPE
INTEGER QueueLength
LONG TimeLineID
DEFINE_VARIABLE
LONG SonyTLID = 1
Dan
I don't know of any other way to make a variable hold n repeat. Hold a button and increment slowly and after x amount of seconds increment fast. I don't even understand their full potential yet but I'll admit I am a little simple that way.
Your changed rate of holding & repeating can be accomplished via HOLDTIME btw. This code will pulse every second until 5 seconds have passed, then it will pulse twice a second.
Doh! I must have read that line thirty times, and the word "constant" slid past my eyes every time. It's still a shame that I can't put it all in a structure to keep it nice and clean, but I'm sure I'll survive.
Thanks!
Dan
BUTTON.HOLDTIME, that's one of those obscure Button_Event Data objects that I'm sure I seen before in a list but never imagined a use for it. Your method also support any number of repeat rates if needed. I must admit it took me a couple minutes to figure out how it works and I'll also admit it's a much simpler and elegant way to do a variable hold and repeat than a timeline.
Sometimes I think my brain takes the long route just for the exercise!
Dan
I suppose you could declare the timeline IDs in an array and give each of your objects an integer that represents which slot in the timeline array that object's timeline is in... but we've already established that OOP principles aren't going to work here so let's stop trying to fake it
That is an excellent point!
